Wiring a French extension lead
I assume that's not quite legal? even if they accept the same plugs thesedays.
But they don't. In general it is only moulded cordsets that have the CEE7/7 plug that will fit French and German sockets.
All the plugs and extension leads I have seen for sale in the sheds are the French CEE7/5 type which won't fit German sockets, and quite right too as the German sockets are not polarised.
So what are the ramifications if I have a string of sockets and some are connected live to right pin and some neutral to right pin ( this in a modern supply ) ?
If you have devices with single pole switches you could end up switching the neutral.
Personally I would go round rewiring all the sockets so that the live is on the right pin.
The French really need to get this standard added to the Normes.
Which for most small appliances really is of no consequence. Far too much is made of this supposedly "dangerous" situation in the U.K., but the fact is that in most cases it really doesn't matter which side of the circuit a single-pole switch on the appliance opens.
The argument for, let's say, a kitchen blender, is generally along the lines of "But the motor will remain live even when the switch is off." Yes it will, but so what? The motor is still safely contained within the appliance, insulated from anyone touching it, just as when it is running.
If the appliance is double-insulated with a two-pin plug of the type used across most of Europe, then there is never any way to guarantee which side of the circuit a single-pole switch will end up in, because the plug is reversible in all the types of outlets it will fit. The same was true of the old 2-pin British plugs & sockets.
There are some cases where polarity and switching may be considered important, but for by far the majority of portable appliances, it doesn't really matter.
If you want consistency throughout the building that's fair enough, but for the practical purpose of trying to guarantee specific polarity of connections to devices it won't do any good, as the European cordsets can be found with brown & blue connected either way around (as well as the 2-pin plugs being reversible anyway, as mentioned already).
