- Joined
- 27 Jan 2008
- Messages
- 25,302
- Reaction score
- 2,957
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
This can go into infinity, however with maths it does matter what grade, 'A' level is grade 3, but not sure if that is the same as 3rd grade? And with 'A' level in advanced maths they do imaginary numbers. But not is seems with normal maths, so when setting a question to solve quadratic equations it is rather important to ask for 'real' answers, or students who have done imaginary numbers can spend a long time trying to work out the answers where it was expected the answer was there was no 'real' answer.
We see the same with electrical questions, in the main volts x amps = watts, it is only when we advance do we say volts x amps x power factor correction = watts.
Also as the trade branches, what is expected changes, I remember moving into installation and being told how important not to mark the gland, so must use spanners, pipe wrenches were a no no. And I was taught one terminal has one wire, moving to domestic where three wires are stuffed into one terminal went against the grain.
As as to cable carrying capacity, the currents in the auto side of the trade are a lot higher. And with vehicles we did things which one would never do with low voltage. And the idea of changing the use of a pin in a plug, seemed daft, but pin 2 with a 7 pin trailer plug has changed what it is used for so many times. Vac warning, inertia light, reversing lamp, rear guard fog warning, so pin 2 always fused.
And when head lights were wired as pairs we would never fuse, only when it went to left and right did we fuse, I remember one vehicle used an auto resetting over load, driving at night when head lights go out is not funny, then just before you hit some thing they come back on, seem to remember CF van but may have got it wrong.
The same with live dependent machines, seems medical items can have a 13 amp plug without a fuse? Seems wrong to me, but seen the red NHS plugs with no fuse.
