wiring a salus rt300rf room thermostat
29 Aug 2009
hi
i have a firebird superQ boiler and i want to add the above wireless room thermostat to work with it.
details provided for wiring into the external thermostat loop of a boiler.
NC- normally Closed (not used)
COM - Live feed from boiler external thermostat loop.
NO -Switched live feed back to other side of boiler external thermostat loop.
L - Live permanent feed.
N- Neutral
My Question is
do i send the live feed thats on my boiler control stat to the COM terminal on wireless stat which is then switched through the NO terminal to the control stat on boiler when room stat calls for heat .
I think i am right just have not done one of these before.
wiring for superq can be seen in link below :confused:
thanks
http://www.firebird.ie/Portals/0/docs/Super Q Installation Manual.pdf
Hi
Can anyone help? it is a Salus RT300RF thermostat and i want to know is where do i get the switched live feed from on the boiler .is it the control stat ?
thanks
