- Joined
- 27 Jul 2015
- Messages
- 12
- Reaction score
- 0
- Country
I have bough a new shed and want to use it as a workshop. I have bought a garage/ shed consumer unit rated at 63A 30mA RCCB with 1x 6A and 1 x 16A MCBs.
I want to take the power for this from an old shower circuit which has been switched off. The shower was on its own single fuse box (30 amp) wired into the busbar on the consumer unit. And the 6mm cable still goes into the loft albeit it is dead because the fuse box is switched off and fuse removed.
My plan is to make a junction box up in the loft and join outdoor cable to the existing 6mm cable that powered the shower and lead this outside overhead to the consumer unit in the shed. Is it ok to join a smaller cable (2.5mm) to the 6mm cable because i cant renew the cable all the way back to the old fuse box that powered the shower.
Also the fuse box for the shower is rated at 45amp but has a 30 amp fuse in it, do i need to downgrade this as i don't think i will need 30 amps of power going to the shed. Or would i be better just taking the old shower fuse box away and wiring direct to the busbar?
Cheers for the help
Stuart
Cheers for the help
Stuart
