A
Alarm
aico do a pre made relay base Ei428 Relay Base .
So they do, thanks for that.
Added to memory banks
Looks like This Ei428 relay base should do the trick perfectly,aico do a pre made relay base Ei428 Relay Base .
My system is not the RadioLINK, but it says it can also be used with conventional hard wired interconnect systems.
There are no areas set for 20 Unarmed Fire Comshi check area options 21 unarmed fire comms. if this is set you wont get a fire ouput if the panel is unset.
Just tried that, no differance, I still get 2 calls first fire alarm then intruder alarm.you need to set it A
what output type are you using for alarm ? where are you connected ?
