Do you mean that if this jumper is altered the Constant, Twice and Once settings will then always be the same for both the CH and HW circuit sides and one cannot set CH for say Off and the HW for Twice?
No. If the jumper is in the A position you can have the heating on by itself. But you said this was not possible, so the jumper must be in the B position. I was asking you to confirm this.
However, you seem to be saying that the jumper is in the A position, which is illogical as you say you can't have heating on its own. Unless you are just theorising and haven't checked the actual position of the jumper.
In practice any operation of the heating circuit does actually turn the HW circuit on though. You can however set the HW to say Twice and the CH to Off and the heating does not come on when the HW fires up in that configuration.
That is what I would expect! You can have HW on by itself or HW and CH together, but you cannot have CH on by itself.
If the HW cylinder has no circuit valve that shuts off when it reaches temp there must I presume be a chance of seriously overheating the water in very cold weather. Obviously this wastes energy but could it ever get so hot the tank explodes? I know that in very cold winter weather the hot water in the tank does become already become very very hot (feels like 65C to 70C) if no water has been drawn in recent times.
As the boiler temperature will not exceed about 80C (controlled by the boiler stat), the water in the cylinder cannot exceed the same temperature, so there is no possibility of it exploding. In any case there is a safety vent coming out of the top of the cylinder which discharges into the cold water tank. Many people with this type of system will turn then boiler thermostat down to about 65C in the summer. This allows the water to heat up to about 60C.
If you want better control, you have two choices:
1. Convert the system to fully pumped This will require a change in the piping, a motorized valve and a cylinder thermostat.
2. Add a motorized valve and cylinder thermostat to existing system. This will not be so efficient as option 1 since the water will still circulate by gravity from boiler to cylinder.
Here are diagrams of the two options; 1 on left, 2 on right.
View media item 69 View media item 827
So you are saying that Blue for Switched Live and Black for Neutral is actually the normal colour scheme in a central heating room stat circuit? Obviously this is confusing for the novice compared to use of brown for live and blue for neutral in the plug wiring of a normal appliance.
No! There is no standard convention for wiring heating systems. Each installer has his own method, some better than others. I deduced from the info you gave that red must be live and black neutral so, by deduction, blue must be the switched live.
when Red was attached to Live and Black to Dem on the Digistat but with Blue unattached that it blew up. When Blue was attached to Sat and and Black to Neutral or Black to Sat and Blue to Neutral the Digistat was not blown up at that point. However that makes sense as in effect both those terminals did nothing on the Drayton Digistat as it was configured and only Live and Dem were active?
The switch inside the Digistat is a two-way one. It either connects Live to Dem or Live to Sat. If the room temperature is below stat setting it connects Live to Dem and if it is above, it connects Live to Sat. When you connected Red to Live and Black to Sat (blowing the Digistat) the room temperature must have been above the stat setting.
In an earlier post you said
When I had red connected to terminal 1 and Black to terminal 3 but also the Blue wire to Terminal 4 (Neutral) this did not result in the Digistat being fried, even though the heating pump did not run.
Presumably this was before you fried the Digistat, so the only logical explanation is that the room temperature was below the stat temperature when you did this test. In any case, if black was switched live it would not fry the stat.
So you are saying these enhanced features won't operate here because they relate to information coming back from the boiler by being attached to the boiler's fire up or stop firing command circuit?
Unfortunately they are not that sophisticated. In any case an older boiler, like your mother's does not supply the necessary feedback. I was just wondering whether you would get the same level of control over the room temperature if all the CM907 did was to turn the pump on and off? It may work, all you can do is try it.
As for the Optimum Start feature, you would have to ensure that the HW always came on before the CM907 started the pump. This could be an hour or more before the time set on the CM907, depending on the outside temperature and how long it takes to heat up the house. If you set the Tempus 7 so the CH side is On then the HW side will also be permanently On. Similarly if the CH is set to All Day the HW will also be on All Day. As you said, turning on the CH always turns the HW on. It has to, otherwise the boiler would not light.
