Wiring Heatmiser wiring centre to Vaillant 630
21 Jul 2004
Hello,
I've got a Vaillant 630 boiler and trying to wire up a UH3 heatmiser wiring centre.
Not sure where to connect the Boiler "in" and "out" on he UH3.
Anyone familiar with the 630 connections? Have an 24v = RT with a link wire going across it atm. Is this the one the connections need to be made to?
Not sure if you are talking about the wiring centre or boiler.
I can see no RT on on-line diagrams for the UH3.
RT with link on the boiler is for Volt free Room Thermostat.
The boiler has a connection called RT.
I am trying to wire the UH3, the heatmiser wiring centre. It has a connection in there "Boiler" with an "in" and "out" connection to be made.
It has two:
one for volt free thermostat, and
one for 230V thermostat
It depends on your system.
Thanks.
It's an S Plan plus system. 3 zone values. Upstairs heating, DHW and UFH (for which zone value is yet to be added). There is one wire from RT 230v, going to the megaflow junction box. The DHW and UFH have orange wire connected to this. So assuming this is the switched live.
Is this where the UH3 should be connecting to? Where does the other wire go, as there is an in and an out.
Brilliant thanks.
Wondering if you can help on this too...
I have neostats for the the UFH downstairs. I also have bought one for the upstairs radiators. Also have a neostat HW for the DHW.
Is UH3 specifically for the UFH only? Im assuming the upstairs rads do not wire into the UH3?
Are they simply wired in as separate controllers?
Im going to have 5 actuators on my manifold so was advised this is the one I need.
