Wiring help for kitchen, slave and master (Lightwave)
15 Sep 2015
Hampshire
Looking for guidance on replacing existing switches in our kitchen with some LightwaveRF ones I've bought. (LW420 Dimmer (2 gang) & a LW450 2-Way Dimmer (1 Gang))
It's a bit confusing as it uses a signal wire and if wired up incorrectly could kill the switches.
Would it be a problem using the existing wiring that is in place?
Existing Layout:
_hDYk43p2hxs9U_KQkO0USSUEH_sguw0R-vygukj0SoXg4eE4SboRya_x5NLIwCmDZDABBg_xAGqNyngSy9cn08pxD6waB5Oj3JQjAyRCJuAPg7ymtqcY0f6PnkhfaMbrngXZOvN
Right side wiring(1): (I should have got better pics, hopefully these will make sense)
dN23A7Pkl7ozUXs9gIq0PdeP0bJYcR7FtZG9dmIymvbmePzmvIEVfvGuCXHMnk9aFgrfppjAuX7vZ9czbVIlEBxsdzVOWA4ooTT4HiB-T83qmRQVD4QP6pNuh-9otDJo5NxkJawg
Right side wiring(2):
siRmf_CtXk8-P9E37_Y1RFsFS-omqemouEfpuuM4kR0ZjxtV6JtkaC8jFtymVSqcA8Awtg71A_ywT1E-dLbRBlhEYtT6CeGp659rWYNkT-awPaIThCli-OoyCzjuEpKgcdqyiYbb
Right side wiring(3):
2H8J0iZR_1UoV8dpEih8Lu3cc2Juumqhj42UCc_dyE4bY80CXbEwcqdIN4-99mwNWAcMzd76Ltrp6db46lBeCUqrG9d7wviPtx5TBeBHv04vOD_GtW2NC4fWXdrivXonS6-Xh2t5
Left side wiring(1):
YcaEZ3xa4BzaK0V37h_gW61-X0GAEpP5UgnHLmEM_eOd9lof8ibdZxRxrE2zjZyl4gSIMt0GV1zaTW35l7LPtawpKtxSRSFSduL-ZLUTczyeJqHHVpiiLFv7XEA-Nj_AQF9SQgZZ
Left side wiring(2):
E6pq4-jTqs3ovXx8tCmlihJBdea0V8WDT3sWP_li6tXhrcEWzRgv2a8jLR1RjcagC0BZaZuo66nt2Q4LnQEWAxEb8caJlvbquqvFsXg37f5OhWbXzmzmehsp1z3g_8eCXLdC0Ftp
LW450 2-Way Dimmer (1 Gang) - To replace existing left switch
1gQCJAz8nMfm2o5Cl6u_bx-xrMGZSsLgxoslIGFSqaVZuNaq6fZuleZRCzAJnIu__1tdaMWyOKBhvcUnS0Npzdu7H31mFKb8AQMf1MzpnlDkv--qHIO2C89xnqEM1GdoMnGihETk
LW420 Dimmer (2 gang) - To replace existing right switch
MrPrP9TBj4VIPP_pQDS5fw4qtO_imuYRx2n3PfVTpHoffpbvgqy9VCeEs9OwYabtLMWCcyc-C4srGgcyO4SuYx6vKPOnLX8sqQPd75u5sVqHDMOMwFT4-b0GZ8TH19aYSjZ1yfve
The back of the two LW switches:
JL5KoXGBwvQ2eHO4q2gEIbSX4yXErd0biIKLZp7oLYnQloqEnD4LuMNslDYLzS74qF72cmlc8CHkH6_d4SYKhlo-B7pDS-qs8uYe5pJ-uiYyr_mPMFGezcsucBbDkcldKClWyith
Thanks up front for any help or advice!
I think you may be out of your depth there, even someone on site may struggle sorting that.
Your 2 way is too be wired the same as the drawing in the wiring diagram
red = grey = S
yellow = brown = L
blue = black
The 1 gang switch will connect to the other switches 2 terminals and not use the "S" terminal.
Not sure why it looks as if you have a red wire in the earth connection.
Why on earth do you want a dimmer in the kitchen? It is a work room with dangerous tools and you (or your wife) needs as much light as possible.
AS far as I can see, from the diagrams, you need a one gang master dimmer and a two gang dimmer that has one half as a slave and one gang as a master.
You've got a two gang master and a one gang slave.
I don't know the Lightwave stuff, but I rather think you will not be able to do it with those dimmers and your wiring.
I think the instructions confuse the issue, you may be better posting the ones supplied with the units.
To me it looks like you have a 2 gang master, that above they call a 2 gang "standard dimmer, that can be used as 1 way or 2 way
and a 1 gang slave that above they refer to as a "2 way" dimmer, that can only be used as the second switch of a 2 way system
The first drawing shows one gang of the "standard" and the second "2 way " dimmer used as 2 way.
The second drawing shows how the other gang of the "standard " dimmer would be used as 1 way
We don't consider it a on/off work environment, especially one that needs 100% brightness for any use. :sneaky: It currently is partly dimmed via other means.. and when we need the light bright, we turn it up. If its just a quick pass through for whatever there is enough light for the need. (Even if from only the fish tank light in the middle if that's the only one on at the time.)
Maybe I should have mentioned it's a kitchen/dining room setup. Kitchen has the 2 gang switch, dining has the 1 gang. We tend to spend 80% of our waking time in the partly split room, one side or the other :)
red = grey = S
yellow = brown = L
blue = black
Yup, there is a short red used as an earth.. no idea why. The new switches don't require earth at least so those will just be removed.
They said it would be easy, can be wired to your existing wires they said :ROFLMAO: ... looks like I'm going to have to give Lightwave tech support a call Monday! If it requires re-wiring, I think I'll just be returning the lot instead.
Oh, trust me.. those are the instructions that came with each switch. Scanned them in myself :sick: .. Think I've read each one over countless times trying to work it out. Even took a chance calling support today to see if they're the right match together. (Closed on weekends) ... their online vids are of not much help either. Confusing is an understatement.
I'm not sure myself TBH. When I fist looked into buying to try, that seemed to be the pair to match up.
And I did find this now which use the same switches: https://www.diynot.com/diy/threads/wiring-for-landing-light-lightwave.413336/
Hopefully the OP is still active and will see my msg there.
As with all two way switching it is like for like between switches, however with the dimmers switch line and permanent line becomes important. It would seem you have a yellow as permanent line with red on single switch (L on new switch), blue as switched line with black on single switch (will go to sine wave with line through it), and red com on old switch goes to S on new. Not sure I like the mix of colours think I would change them.
Other switch S not used.
However we are assuming with twin and earth red is permanent line, and black switched line, you need to check at the rose if that is the case, also check that the triple and earth simply goes switch to switch, if you need to be 100% ringing out is only way.
