No you are not.Obviously if you can't tell I am not experienced at all!
And you are also ignorant. You think that one of the conductors is a neutral, you have no idea what switches do, and you're proposing to wire it up so that it will connect live to earth.
No you haven't.I have wired the neutral and live as per the diagram
No it doesn't.which also seems to show the earth/green needing to be wired in to the top 'L' terminal
What grounds do you have for "knowing" that?I know I can do this
It is a quick job, for someone who understands what they are doing. You don't.don't want to pay for an electrician for what should be a quick job.
If you'd gone ahead with your idea of putting the earth into L then some or all of these would have happened when you turned the power back on:
Or possibly, if there are things wrong with your electrical installation, other metalwork in the house becoming live.
Attempting to do electrical work without a proper understanding of what you're fiddling with is a stupidly dangerous idea. You should not be blindly following instructions to put-this-wire-in-that-hole without genuinely knowing why.
Please either get an electrician or put all plans to actually do any electrical work on hold until you know what you're doing.
