I recently purchased 8 spots (50w) with 3 seperate transformers as I was told I needed the following:
- 2 x 210w to drive two sets of three lamps
- 1 x 105w for the remaining two lamps.
Transformers
http://www.alertelectrical.com/Ligh...10wva-12v-Electronic-Lighting-Transformer.asp
Spots
http://www.alertelectrical.com/Ligh...-fixed-square-downlight-in-Antique-Brass-.asp
After reading several posts, I understand you shouldn't use jb's unless you can easily gain access.
The diameter of the hole for the light fitting (70mm) is big enough to slot the transformer into the ceiling void but not enough to get a jb in.
What is the best or should I say correct way of wiring the lights up?
Appreciate any advice.
D
Transformers
Spots
D
