Afternoon.
I want to fit 3x LED PIR Floodlight 10W PIR 820lm at different locations around by house/corner plot after a recent break in.
My house wiring is still original from 1960/1965 roughly when it was built, still on fused box not a consumer unit etc if that helps.
I was wondering is the best way for me to tee of a 3amp fused spare switch from a 2 gang socket (chisel out wall and fit switch at correct height)
and then use some Weather Resistant Rubber (Pond) Flex Cable (3183P) 0.75mm from the fused spur to my security light mounted outside. So i can just power down the
PIR lights in the day time and just flick them at night if movement is seen?
Thanks?
Thanks?
