Hello
My garage is attached to the side of the house. All the wiring from what I can see/work out is 2.5mm T&E.
At the moment there is a double socket in the garage, the wire to which disappears into the house (somewhere under the 1st floor floorboards). There are no sign of any fuses or anything up-wire from this socket. There is then a wire from this socket to a fuse, then from the other side of the fuse it goes into the conservatory light switch, from which it goes to the lights in the conservatory. There is another wire coming from the house, which goes to the light in the garage - and on to two switches (This is connected to the 1st floor lighting ring).
At the moment it seems to work. However as I'm wanting to add more sockets to the garage am thinking that I would sort the above out at the same time. From what I can work out this socket is an unfused spur. Now reading the rules I understand that I am allowed at most a double socket on an unfused spur, is this correct? If this is correct how does then putting the lighting for the conservatory affect it?
Also there is also a wire that comes from a double socket in the conservatory, at the moment this is not connected to anything, as it was connected to the lighting side of the fuse, but I was not happy at the time of having a fused spur (and lighting) from an unfused spur.
In terms of what I want is another 3 double sockets in the garage (in addition to the double socket that is already in there) and a waterproof double socket on the outside wall of the garage and to connect the double socket in the conservatory up. Also a couple of extra lights (these are for use over the workbench - although I could always use desk lamps plugged into the socket)
Now as I understand it I can do one of the followings:
a) make a 4 fused spur's and attach each of the double sockets to one of the fused spurs, I have enough sockets in the house to allow for this (I understand I can do this and not have to inform anyone)
b) Turn the existing double socket into a fused connection unit, then just daisy chain all the double sockets together - knowing that the 13A fuse in the FCU will blow before I overload the circuit beyond (I understand I can do this also and not have to inform anyone)
c) Wire in a new Customer Unit in the garage (like this) and create a new ring for all the double sockets and lighting in the garage (including the double socket in the conservatory). Taking power from the House Consumer Unit (I have a couple of spare spaces). This I would need either to let an electrician do, or notify the local building regs people and get them to check it etc.
Is my understand correct?
At the moment I'm trying to find out my options, which is the preferred way, what each option will cost me (both in terms of money and time) etc etc..
Just a quick question on option c, is it allowed for me to say do 90% of the work (i.e. putting the cables in the right places, wiring in the sockets etc etc) if an electrician came and did the final testing/connection? Or would this be down to the individual electrician himself?
Cheers all
Cheers all
