as i live in N.ireland i know the Regulations are not the same as those on the UK mainland
FFS.
unless you live in NI ....
As you don't know me or seen my work and know what im capable of doing HOW CAN YOU sit on here and critasize me and tell me i have A LOT TO LEARN.
Having a lot to learn is not a criticism - it's a simple fact.
Maybe my 1st post wasn't clear enough all i need to know is garage sockets to an existing downstairs socket or the cu same for lights to light or cu
Anybody who was genuinely competent to carry out electrical design work would not have to ask questions like that.
You also don't understand the pros and cons of ring finals vs radials, because if you truly did then you would be able to make your own decision on what to use.
But the fact that you are asking questions like that shows that you are not yet competent.
And that is not a criticism, nor is it a suggestion that you are incapable of becoming competent.
It strongly suggests that there is a large gulf between what you know and what you need to know.
Would someone who doesn't know about the things you're asking about nevertheless know about cable installation methods and de-rating factors? Voltage drop? The relationship between
Ib,
In &
Iz? The requirements for concealed cables? The requirements for main and supplementary bonding? MCB curves and earth fault loop impedance? Testing?
Asking questions here can be a useful part of a learning process, but they are not a substitute for proper structured studying. The key term there is "learning
process" - you cannot learn all the things you need to know just by asking questions here. It isn't structured enough - it won't provide you with a way to progress where each step builds on what you learned before.
You can't become competent by asking whatever random questions happen to occur to you. What if you get something wrong because you have no idea your knowledge is wrong? What if you miss something because you simply have no idea it even exists, and just don't realise you don't know it?
There is no reason to believe that you could not acquire the knowledge you need, but your building project is at this stage:
i hav almost finished my extension garage ground floor bedroom/ensuite 1st floor and about to wire it"
And your knowledge is at this stage: "
were do i connect sockets 1st floor and lights/sockets in garage...ring circuit or radial ?"
There's a disconnect between the two, and you don't have the time to rectify that unless you put the building project on hold.
