Wiring of light switch
but I was trying to save a bit of cash by installing the lights and wiring the switch myself
If you put all the wires in and lights then as asked , draw a diagram of what you did
colours of wires , dont mean anything on there own, its you who would have used the colour of the wire to connect up things
so saying
With the lights I'm just placing the blues together in one hole and the browns together in the other hole, and earth to earth of course.
doesn't mean a lot
Blue can be used as a switched Live, so NOT a neutral ......
so a simple diagram showing the setup
ONE WAY TO WIRE
assuming that yiou =have 2 lights and you used 2 bits of T&E for each light
then you would have for each light , if wired as convention
Brown - switch live
Blue - neutral
Bare - Earth (needs a sleeve green/yellow
and then the 3rd T&E would be LIVE/ Neutral form a power source
so the LIVE from the power source - Brown - would goto COMM on the switch
The other 2 Browns - switched Live out to the lights , would go in L1 or L2 - matters not - just how the switch would work for on
BLUES all together in a wago - and NOT connected to the switch at all
BUT there are manyways you could have put the wires in
can you do the following as asked in previous post
ok, so how did you wire the lights up ....
do you have 3 T&E cables , what does each one do ????
Live/neutral IN
switched Live / Neutral to one light
switched Live / Neutral to second light
if its a new installtion can you draw a diagram of how its all setup ?
