- Joined
- 2 Aug 2016
- Messages
- 2
- Reaction score
- 0
- Country
Lots of good advice on these boards about external wiring, but I've not found anything similar to my problem ...
I plan to install a shed about 7 metres from the main house where the electrical run would be across a tarmac parking space and lawn. I can't suspend the cable due to trees.
The problem is that the trench will need to cross over a domestic sewer pipe that runs across my land, so the cable will either have to go above or below it (the sewer pipe is about 0.5m down).
Can I use shallow cable troughs with clip-on tops sunk into the ground?
This would be the same thing that rail networks run alongside their tracks and are strong enough to support vehicles. Cable will be SWA.
Apart from sourcing them, the two major problems I foresee are damp and rodents, but if the railways can cope with it ...?
This is the kind of thing I'm thinking of: http://www.cubis-systems.com/uk/products/cable-protection/mm-railduct/
Has anyone done something like this?
