Now that the conservatory is built I need to sort the lighting. Originally I had a PIR light 300w on the outside running of a wall light within my dining room - this was the way it was wired since a new build in 2003. Anyways the light switch has 2 cables running into the back box: 3 reds running to the switch, earths going the the back box and nuetrals running to a choc block. The circuit running to the PIR is now redundant as I'll be mounting the Air Con evaporator on the wall where the PIR was. My question is can i run 1.5mm lighting circuit from the back of the switch out through my cavity into the conservatory cavity to run my 3 single spots and disconnect the redundant PIR circuit?
Other ideas was to spur off ring in conservatory with 3 amp fuze and then put a new switch on the wall, but I'm looking for the easiest option here. Clearly not a sparky but aircraft engineer, so any advice would be appreciated.
