Wiring up new thermostat
4 Jun 2007
Fitting new Comi-stat thermostat(drayton rts8) to worcester 28cdi combo boiler. The thermostat connections are live, neutral and neutral load (call for heat......is the neutral load the switched live wire. I have a drawn diagram of where to connect the wires into the boiler.
Thanks in advance
Thanks in advance
the connections are
L = live
N = neutral {if you have a one)
3 = call for heat
If you have no neutral then
for loads of between 0.6 and 6 amps
as above with the omission of the neutral
for loads between 0.1 and 0.6
use term 2 for call for heat
Thanks will wire it up tomorrow. Looks like adding in a loop.
