Earlier this year, we noticed water running down the outside of our twin-walled wood-burning flue when it rained, gathering on the top of the stove. We fitted a storm collar, which briefly seemed to solve the problem. However, the water soon returned with the rain. I have since removed the ceiling finishing plate, and as the photos from when it was raining show, the internal surfaces of the flashing and flashing rubber are both wet, as is the rafter bracket and membrane. There also appears to be mould on the lowest rafter, which can be seen in the photos. We also have visible damp patches on the ceiling close to where the flue is installed, albeit above and below (and behind) it. The guy who installed it has disappeared, and the couple of roofers who have looked at this have either been unable to help or reluctant to assist due to the flue. There is also what appears to be efflorescence on the external wall beneath the coping stones. Therefore, I’m reaching out for advice on properly addressing this problem(s) because we’re now stuck with a leak that we don’t know how to fix. My questions are:
1. What could be the cause of the problem, and how do we address it?
2. Is the dampness in the ceiling above the flue likely related (there is only damp in the area of the flue)?
3. Can we treat the mould, or are more drastic measures required? If so, what?
4. Do we need to check the length of this rafter to see if there is more damp?
5. What is the cause of the efflorescence?
Thank you.
Thanks all.
Thank you.
Thanks all.
