Go on, help us out, what are you wanting to cut
WoodGo on, help us out, what are you wanting to cut
I have a feeling I know who the gormless one isSeems Screw Fix next door as as gormless as ever!
Don't mess about, get one of theseWood
where can i buy one of those from? will i need someone on the other end to pull it?Don't mess about, get one of these
The old "health and safety card"? Really? That's very weakI knew the old health and safety card would be through in as the exsuse of if you dont destroy the independent lively hood of your jobs and business in the name of lockdown then we are all doing to die! (shame it was a hoax ay)
In action it is a grinding wheel - as stated aboveso it dose not say the tool is unsafe right! but is the blade cutting or grinding
No I have not used one; but for cutting wood are they as much use as a metal grinder/ cutting blade?As to your linked disc, have you ever actually used one of them? I actually doubt it. But I have uzzed them, and I know that they aren't specifically designed for cutting wood - much more for handling composites such as cement fibreboard bonded onto OSB, and the cut quality is pretty horrible on that in comparison to a regular carbide tooth saw blade used in a portable circular saw being used on OSB alone. The Bosch blades can also kick back pretty viciously if you over feed them or twist them in the cut (just like a conventional grinding disc will), and they don't last too long on wood, either. In point of fact they are designed much like the segmented discs used to cut stone and metal (on a grinder) without any teeth. The cutting action is as a result of carbide grit bonded to the outer edges of the disc abrading its' way through the material like a grinding wheel would abrade its' way through stone or metal. So they aren't a saw blade at all - but like any other grinding wheel they need to be used with respect.
Kindly read what I wrote again - NO, they are not much use for cutting wood, they cut as rough as a bears arris (because angle grinders have no base plate and therefore the cut cannot be as controlled as it would be on a portable circular saw) AND they are a lot more risky to use because you use them on a grinder, which is inherently more dangerous than a circular sawNo I have not used one; but for cutting wood are they as much use as a metal grinder/ cutting blade?
