1 Apr 2008
Devon
Hi all,
The handle on the Woodwarm woodburner door has become very stiff - it's the handle and catch itself - it's stiff whether it's open or closed, so it's not a problem with the door or seal.
Ordinarily I'd clean and lubricate something like this with WD40, but I'm thinking that may be a bad idea as it gets pretty hot.
Any ideas?
Thank you, Stephen
can you take it off and dismantle?
look at the fit of the pivoting parts
are they a tight fit? clogged with tar? thickened by rust? bent out of shape?
you could ease them with a file or wet-and-dry paper
this is one of the (very few) occasions when Copaslip can help. Even after the grease has burned away.
I'm so impatient!
I squirted a little GT85 on it, and used a metal pipe to open and close it enough times to loosen it up - it's fine cold - hope it doesn't seize up again when hot!
