Worc Bosch boiler playing up...
When you replaced the isolator did you ensure that the screw was pressing onto the wire and not onto the terminal plate with little if any pressure on the wire
I've always thought terminals with the little plate were better quality, and the wire should be under the plate (other side from the screw). So the wire is gripped but isn't subjected to screwing action, specially for multicore flex, less important for cable. Is that wrong? If the wire goes between the screw and the plate what's the point of the plate?
