Maybe just another thing to consider regarding the micro switch. When i removed the two wires connected to it I noticed they were both the same colour (pink) so I assume that it doesn’t matter which way round they go when reattached?
Problem solved! I noticed,when looking at the diverter valve diaphragm pin from underneath that the black plastic disc was missing from it therefore it couldn’t operate the switch. After a quick look around I found it wedged between the floor boards under the boiler. Reattached it and now hot water!
Thanks for all your help. Really appreciated.
