Ok, so you turn the shower/ bath on (mixer shower) and pilot light on boiler ignites, hot water comes on but after several minutes (varies) the pilot light goes out, then you hear a clicking noise on the boiler (clicks every half a second, to try and re-ignite itself i presume). Sometimes it manages to re-ignite itself on its own but usually i have to give it a quick whack on the side of the boiler (at the bottom where the PCB is housed) and it will re-ignite itself after i have whacked it.
The pilot light then sometimes stays on for a while but also sometimes goes off after a few minutes/seconds.
The place where i whack it is where the PCB is OR the connections leading to the PCB.
Also the boiler sometimes completely fails to ignite sometimes and doesnt even try to ignite, the only way to get it to ignite again is by switching the boiler off at the mains and back on again.
Hope someone can shed some light on my problem.
Many thanks in advance
Phil
Phil
