Worcester 350 relay RL 1 buzzing loudly
11 Mar 2006
Hi all long time no speak :D
Worcester 350 Combi with "built in" digital timeclock.
Extremely loud buzzing/vibrating from Relay RL1 on right hand side pcb (the one with two boards linked with ribbon connector).
Overheat Stat has continuity.
Low Water Switch = Live on white, Live on Brown.
Removing plugs one at a time from pcb's does not indicate location of fault (e.g the buzzing continues).
Removing Low Water Switch or Overheat Stat connections from pcb stops relay buzzing, but i assume this is only breaking the power to Relay RL1 and not indicating the actual faulty component.
I suspect the pcb is gubbed, but i wanna be sure as its a bit expensive.
Any ideas ? And if it is the pcb what could have caused the faulty relay.
Mucho thanks.
Try tapping the relay, not ideal but can work, otherwise new board
