My parents boiler has a problem.
It is a Worcester Greenstar 42CDI.
Around 1 week ago we noticed the boiler had low pressure when in use (central heating). The pressure gauge was in the red, below 1.
We filled when off (cold) so pressure was between 1 and 1.5 as per manual.
Last night they noticed the radiators making a whooshing noise. The pressure on the boiler was at zero, when on.
The overflow pipe outside (not the condensate pipe), the little overflow pipe was spewing water onto the floor.
Immediately turned off boiler.
Questions;
- what is this?
- the company they are with are not taking calls now due to covid, can they do anything themselves?
- is it safe to use with zero pressure? Central heating or hot water.
- filling up the boiler again, the pressure goes back to zero after a short while, even when the boiler not in use.
Obviously a difficult position as they are elderly and with covid, getting someone out is a bit of a problem. So a bit of a panic really since the weather is now excessively cold. Any advice appreciated. Thanks.
Questions;
- what is this?
