- Joined
- 8 May 2017
- Messages
- 10,112
- Reaction score
- 2,615
- Country
Did you close both valves on every radiator ?
Yes, except 2 in the loft conversion. I turned everything fully anticlockwise which is off for the other 8 rads. Except these two. Doh!Did you close both valves on every radiator ?
That depends on whether you're above or below the valveFully ANTI clockwise would open them fully ??
It's a 1930s semi with a suspended wooden floor. The floor was replaced with large MDF boards with Celotex glued in between the joists 4 years ago after the whole house was replumbed and rewired. I think it reasonable that the soil beneath the house is damp during a rainy October.Don’t think you’ve given any info on what age or sort of house you have but would you reasonably expect the area under the floor to be damp or could that be a result of the losses from the heating?
Should say I think it’s unlikely the radiators or their valves are the problem; I’d expect it to be fairly obvious if they were leaking so much water.
