Hi Ian,
Is the finish on both ceilings the same, i.e smooth, artex, stippled ????
If you are only intending to 'patch' the gap then you are correct in what you are saying by leaving a small gap in between the existing boards & your screw gap lenght.
I would add flexible gap sealant inbetween the gaps of your cut edges (just to minimise the threat of cracking) then scrim tape, PVA the mating edges of the existing ceilings then plaster over blending into nothing about 6 - 12 inches into your existing ceilings.
If you required the complete ceiling to be re-plastered it should only take a half decent plaster half a day with a ceiling of that size.
