T
tonyelectric
Mind you don't get lost round the forest of dean, theres many who've never ben seen, or heard of again!!
Not sure what "requires Part P" means. There can be no doubt that Part P applies to the work because it is associated with the installation and supply in a dwelling.From what you say it is not a new circuit so it is not cut and dried as to if it requires Part P.
I have bought a garage consumer unit which looks easy enough to wire up.
Please tell us which part of Schedule 2B matches the installation of a distribution board and the creation of outgoing circuits from it, and therefore makes the work non-notifiable.Render the switch in the garage consumer unit inoperable and it becomes a distribution board. Then it becomes non-notifiable according to notes e and f:
I never said that; I said "according to notes (e) and (f)". They are part of the Approved Document that is supposed to explain how the law should work. I'm not a lawyer, I'm not sure what the words in a Statutory Instrument mean so I expect the AD to tell me what's meant by them. Oh and the BC is not a lawyer either, so he is not qualified to advise on what's notifiable or not.Please tell us which part of Schedule 2B matches the installation of a distribution board and the creation of outgoing circuits from it, and therefore makes the work non-notifiable.
Is he adding lighting points to an existing circuit? No he is not.
Is he adding socket-outlets and fused spurs to an existing circuit? No he is not.
Your grasp of the nuances of "consumer unit" v "distribution board" show that you do not have a limited grasp of written English, and to claim that you cannot understand the list of work in Schedule 2B is at best far-fetched.
Schedule 2B and Table 1 are nothing to do with each other - they are from different documents, and the former, which is the actual law, makes no reference to the latter.First, Section 2B does not require compliance with all the Table 1 provisions; any one will be enough to make the work non-notifiable. As it is, my case complies with two of them.
No he is not.Is he adding lighting points to an existing circuit? No he is not.
Oh yes he is.
That unenergised 10mm² cable is not the circuit to which he will be adding the sockets and lights. Those circuits will be the ones originating from the protective devices in the DB.The OP’s existing circuit is an unenergised 10mm cable from the CU to the attic, where the excess is coiled up. The OP’s intention is to extend this circuit, via a distribution board to his proposed lighting and power points.
Then you should have no problem in understanding the definition of "circuit", and recognising that one for sockets coming from a breaker in a DB originates at that breaker, not at the origin of the sub-main feeding the DB.Of course I can understand the distinction between “consumer unit” and “distribution board”; I’m an electrical engineer.
"Legal jargon"?However, I think it very unlikely that a lawyer would understand that distinction any more than I understand the niceties of legal jargon.
Well we went through that too, and there is nothing in Table 1 which makes the work non-notifiable unless we go with your definition of "circuit". So, as an electrical engineer, do you want to claim that "An assembly of electrical equipment supplied from the same origin and protected from overcurrent by the same protective devices(s)" does not mean that the new cable supplying the new lights in the workshop, connected to the new B6 MCB in the new DB is not a new circuit?The Government does not expect me or others involved in building to understand legal jargon either; that’s why the Approved Documents have been published.
The definition of a circuit is very simple — 4th form physics stuff. If a circuit is complete and energised, current flows through it....there is nothing in Table 1 which makes the work non-notifiable unless we go with your definition of "circuit". So, as an electrical engineer, do you want to claim that "An assembly of electrical equipment supplied from the same origin and protected from overcurrent by the same protective devices(s)" does not mean that the new cable supplying the new lights in the workshop, connected to the new B6 MCB in the new DB is not a new circuit?
So do you disagree with the definition in Part 2 of the Wiring Regulations?The definition of a circuit is very simple — 4th form physics stuff. If a circuit is complete and energised, current flows through it.
What's your take on the definition of circuit in Part 2 of the Wiring Regulations?Current will flow through a fuse or MCB so that must be part of the circuit, not its origin unless a definition states otherwise.
But then if we go with your notion, that for the purposes of Part P a circuit begins at the very origin of the installation, and can have any number of fused-down branches without those being circuits themselves, then, for the purposes of Part P, you cannot comply with the Wiring Regulations - you're going to be looking more than a bit iffy re 314 if your installation only has a single circuit.Moreover, the notion that a circuit should start from and end at the point where circuit protective measures are connected is clearly ridiculous for the purposes of part P. If this were the case, Building Control would be involved every time an appliance is plugged into a socket because a new circuit and its protective measures have been connected.
1) That does not answer my question - you claim that you can't understand "legal jargon". Is Schedule 2B unintelligible to you because of "legal jargon"?BAS may consider that the language in Schedule 2B is clear for the layman but the government didn’t think so. Hence it published not only the Approved Document in 2005 but further explanations and examples in 2006.
