Worktop & Bench
5 Mar 2008
Stirlingshire
Hi Guys,
First post here!
Im putting a wee workbench in the garage, its a 3M worktop which fits perfectly into the space ive got. Im looking to build a frame which I can strap MDF onto to make my own shelves ect & finish it before painting it, What is the best type / size of wood to use for the frame and how do I fix this to the breezeblock & attach the worktop too. I will have a big tv and a computer monitor on there!
Cheers
what weight are you planning to put on these shelves!!!
idealy an unsuported length of around 1m is ok for moderate loads and mdf shelves fronted with timber
or 0.75 if a bit heavier loaded
providing your not rebuilding engines or heavy hammering on the worktop and assuming you have a fully supporting frame
you will get away with brown plugs every 2ft along the top rail and one cenral and towards the bottom of each back leg into the wall
if you choose not to have a frame but 12 or 18mm mdf i would suggest around every 600mm you place a divider to hang your shelves from
i will go into more detail if you choose this method ;)
