From my experience all electricians at the end of the day have issues....
Junes example ...EICR on a rental, new electrician,
no grommets on back boxes and boxes not earthed - they are all plastic.
No earth on kitchen lights - all fed 12v from transformer - which he could not find - clue its on the wall with a sicker saying kitchen lights transformer and wifi switchgear right above the isolator in an enclosure just outside the kitchen which leads on the "shocking and potentially deadly" his words, state of the kitchen light switches...having no earth...except they are all piezo switches and have no external power.
Same for bathroom - same design. no 240v all 12v fed from outside the bathroom.
No isolator for bathroom fan - he thought the isolator which was for the bathroom transformer 12v was not connected to the fan.....however there is no bathroom fan...the flat has a central fan serving the heat exchanger and 6 room intakes...which does have an isolator but he missed that and disconnected the wiring at the consumer unit as he could not find where the wiring was going...despite having a wiring diagram...
Ring broken and inappropriate mcb at 20 amps- ..there are no rings in the flat they are all radial circuits- he may have been confused as the 3 serving the bedrooms have 2 cables in each mcb..so I am assuming he saw two cables and thought it must be a ring..despite it being clearly shown on the wiring diagram and stated on the consumer unit.
Then he took mcb for the lighting circuit off the rcb without being asked...for safety apparently as the flat would go dark...despite each room having an emergency light fitted...which he might have found if he had bothered to drop the lights or perhaps wonder why the lights all come on when you trip the power or for that matter when they all spark up when you disconnect the smoke alarms or test them or trip the general alarm....which he did when he entered the property as the log says.
Still mus'nt grumble..he got a badge from NICE so he must be good, £375+vat..with a quote to put it all right of £1900....
Second ecir - put right what he had "fixed and redo the eicr -£425 inc no faults found....
