PrenticeBoyofDerry
Yes, thats exactly what I want documented formally by a certified electrician, whether from my builder or elsewhere.
Taylortwocities
Are you suggesting that I only need the certificate for my keeping (to show that the work was done to standards) and that it does not need notifying?
Your problem is that as I previously mentioned, you will be very lucky to find an electrician that is willing to self cert anothers work, without knowing it was installed safely at first fix.
Taylortwocities
No the works are notifiable as they are a)in a spacial area ie the kitchen and
b) works to the consumer unit.
In the shell of a nut your builder is wrong, the extra works are notifiable and as such he shouldn't have used a non registered sparks.
BC will sign your job off as they will be unaware of the new works, whether you are satisfied that the second sparks work is up to scratch is another matter.
If you inform BC then they will then want either the extra works signed off(you may find that hard)or will charge you to inspect and test themselves(could be expensive as they will probably charge for a full test).
Yes, I am well aware of the problem I am in now. I will get in touch with the builder again to see how he can help sort this out. Failing which I will speak to the building control inspector who approved the work.
