Softus said:In that case you have a revolutionary new type of exhaust that can have a hole in it and yet not leak.
No not really, there is a hole in the front for waste gasses to go in and one at the back to let it all out!
You can also have holes that have not made it all the way through the exhaust. Prudence may say repair /replace the exhaust at that point.
mrgtv said:*If* it was leaking, then that *may* come under the category of excessive wear.
Softus said:Contrived nonsense. Holes in exhausts systems are caused by corrosion, not wear.
Again, you are ill informed, thermal cracking is common - as is damage due to impact (grounding) to name but two causes of holes in exhausts.
mrgtv said:I also said, "anything that looks like a bodge" is not a fail as long as it passes so I believe you're agreeing with me.
Softus said:You may believe so if you wish.
So are you, or are you not, saying that a bodged repair on an exhaust that does not leak is a fail?
