Oh dear oh dear oh dear. So I’m building a brick bbq at the end of a brick patio and wooden pergola that I’ve finished and have been “novice DIY’ing” all the way and researching heavily every step of the way. Except for the bricklaying for the BBQ. Didn’t think there could be much to it. Mixed up some mortar to a mix that seemed about right and cracked on.
But it’s oh so slow so I thought I’d watch a quick YouTube to see where I might save some time and it’s pretty clear where I’ve gone wrong. I’ve used a 5:1 sand to cement mix but have used sharp sand. And then I’ve been bashing away at each brick I’ve put down with a rubber mallet to try and get it to squish down thinking I can’t make it any softer by adding water as it’ll just keep falling (dripping) off everything. Quite a different style to the pro gently easing each brick down with an ever so gentle tab of the end of his trowel as the perfectly malleable mortar gently oozes out ready to be neatly collected up and reused later on!
So I now understand that the sharpness of the grains is why it’s so stiff and unworkable, however everything has now gone off and seems very solid…
Will what I’ve done be ok still? Clearly the pointing hasn’t been great but it’s fine for what it is (mainly due to the huge amount of time I’ve spent on each brick!) and a lot of it will be hidden anyway. Also most of what’s already done will have a very heavy granite slab on the top of it holding it in place.
I’m only about halfway through so presumably I should now switch to a proper mix with builder’s sand and a 4:1 mix - will the colour differ much?
Please don’t be too cruel with your replies!!!
