Yale 6400 outdoor siren goes off when not armed can anyone please help
have had the alarm over 2 year now
when it triggers there is no reading on C P U
[Yale 6400 outdoor siren goes off when not armed can anyone please help[/b]
It will be a tamper from your siren most likely.
Check that all the original mountings are still secure.
If the backplate moves then the rear tamper microswitch can activate.
A warning of some sort that does not indicate at the control panel?It will be a tamper from your siren most likely.
Oh boy, you need a decent system
Things that are spot on
I wonder if the (help?) is in the manual?
Why do you continue to defend a item that cannot self diagnose?
skyboy
from United Kingdom
Thanked: 4 times
Ah I think I might have sussed what has happened here...
I think you have been fooled by the following:-
If you come into the home via your front door or whichever is your entry door it will start the panel countdown.
I am assuming now that what you have done then is to rush upstairs to see if the device on the landing will activate the alarm.
It won't not if the panel is counting down.
I assist all, even learnt all about the items spoken about, something you and your mate have not done about other systems that work.
You defend something that has inherent problems. Cannot even tell the end user what the problem is, without looking at screws and lids on ladders.
A real system would pinpoint the issue with a easily read screen or a led sequence.
See the difference?
You won`t, as your blinkered. Shame your not experienced or good enough to help others, seen one correct answer you gave on the electricals. Then you needed a photo, we had worked it out from the description.
What are you doing advising on something others have done for a living for over 30 years and making out your an expert?
~Again childish retorts.
I`ll reply here about how a "yale" does not work if the front door is entered without a code;
As for parents, mine were great. I am too big and always was to be bullied.
I do however tell the truth, Yaleguy1/2/3/ had been banned or had to cancel the accounts. Along with his others. So it is now Skyboy, one who admitted he had issued with the Police and Trading Standards. Admitted by himself.
Enough said.
Which is a risk assessment made without the necessary information and experience of the risks involved. They then get advice from people with a vested interest in selling a particular type and make of equipment. Of course that advice will be biased towards that particular type and make of equipment and will not give independent advice, will not volunteer the poor points of their system and will not mention the better points of competetive equipment.You need to wind your neck in and realise that people actually do their own risk assesments before deciding how much they want to spend
Most people making the assesment will be "impressed" by the words on the box which are all intended to increase sales.
An independent and informed person should make the risk assessment on behalf of the person who requires the equipment.
