yale 6400 burglar alarm problems
Status
Not open for further replies.
It will be a tamper from your siren most likely.
Check that all the original mountings are still secure.
If the backplate moves then the rear tamper microswitch can activate.
A warning of some sort that does not indicate at the control panel?
Oh boy, you need a decent system
I wonder if the (help?) is in the manual?
Well just consider this - when you fit the alarm you know there is a spring at the back of the backplate because you can see it and you can hear it because as you screw the screws into the wall you can hear the microswitch click. You will also have seen reference to it in the manual.
ps
Bert you don't even know what an SAB is.
It would not be unusual to forget this two years later if you had only fitted one system.
However as you say your professional systems alert you to everything in the panel to save you using your noggins and common sense.
Five things are capable of setting off the siren.
1. An activation signal from the panel
2. A signal from a sensor if the siren is in master mode and the system armed or a panic signal
3. A signal from an activated linked smoke detector
4. Movement of the siren lid or base allowing a tamper fault
5. A local RF blocking.
So using the simple process of elimination we can see that according to the OP it won't be 1 , 2 or 3 so we look at 4 next.. :)
simples and you don't need a panel reminder to work through that simple list.
All that diatribe and you leave out one of the most common reasons that causes an SAB to sound, never mind, we can't all know everything.
Perhaps it's the difference between a Pro Alarm Installer & a DiY alarm installer?
Put your brain in gear!! The Yale siren has internal batteries so the most common reason for YOUR SABs to sound ie the electric has gone off and the panels battery is dead does not apply.. :rolleyes:
So AssociatedAlarms aka BANNED member Alarm aka Banned member Youtakindapish aka Banned member Whistle aka banned member . . . . why are you here?
Errr your Yaleguy, we all know it and banned. You had my name "Alarm" banned with certain comments that were deemed unacceptable.
Then you use several others. I have never used any other names apart from this, and certainly not denied it.
Your clearly deluded.
Again you use name calling, how childish. You have not confirmed what the Yale does when the door is opened and someone runs about as your friend JohnD says NOTHING.
So during entry time someone can steal or do other things before the alarm sounds.
Not very good is it.
Even if it is DIY.
A £30 low end panel would do better.
Status
