M
mdf290
Just thinking about the comment above. THE hallway PIR is set to Home Omit to allow movement inside the house (eg from bedroom to kitchen) at night. However the hallway is between the front door (with Entry door contact) and the control panel.
In this scenario, should the hallway PIR be Home Omit, Entry or Away Entry?
Thanks for all the advice.
PS Still haven't solved the main problem but have turned off the WiFi on the broadband router which is not quite a metre from the control panel.
PS2 Tried to phone Yale on both numbers 01902 364 606/647 and never got through to a human. Emails are not answered. I suspect no-one is there.
You should not have to turn off the Wifi just reposition either it or the control panel a little further apart. Have you tried different locations of your door contact?
The hallway sensor should be an entry device if it can pick you up moving from the door to the panel.
If you can move it so it cant see you come in then you can set it to home omit instead
