Hi, I was wondering if anyone can help or is experiencing similar issues with the Yale hsa6200 burglar alarm.
First of all before I start, I have previously installed the same model system at another house with no issues and that's nearly a year a go.
I installed the hsa6200 again at another location and at first everything was working fine. I tested the system and everything was good so I disarmed the alarm and carried on with my day, about 8 hours later the alarm goes off while the alarm has not even been activated.
So I assume it's to do with a tamper switch and check all the sensors, no problems what so ever. An hour passes and the alarm goes off again! I deactivate the alarm again and check the sensors, with no problems.
I then close the front door which knocked the sensor off slightly which In turn set the alarm off, now this is understandable.
So I assume that because the sensor wasn't screwed in it must of been slightly loose or something, so I remove the sensor completely to see if this stops the alarm going at random.
Still the problem persists! But it's not consistent, it could be once a day or five times a day.
It happened as I writing this out but this time I heard the alarm activate first! We don't have key fobs and have one keypad which no one was touching so know I can only assume someone else's alarm is interfering with mine.
Can any body shed light on this?
Thanks in advance
Thanks in advance
