- Joined
- 29 Sep 2015
- Messages
- 1
- Reaction score
- 0
- Country
I bought and installed Yale Smarthome Alarm myself (not installed by professional alarm fitter) . It was not difficult to install and commission. The alarm system works well albeit the following problem:-
All sound from my Yale Smarthome alarm have stopped working, beeps still work.
E.g. I had sound selected for Doorbell, When press it no longer output a tune. I have changed it to ‘beep’ instead which works. Same for Entry and exit duration, sounds used to work, they stopped working changed to beeps as interim measure.
I have restored the control panel to Factory defaults and re-configured all the devices only to find out that the sounds still do not work, beep works.
Please help, any advice/suggestions. Is there a setting that I have misconfigured?
Some problems that I have encountered, however resolved have been added below just in case they are helpful to others:-
1. If PIR sensors were in Soak test mode they will not function. They should be correctly configured for Full alarm and part alarm Scenarios. The installation manual is not clear on this issue, there is no mention of the next step menu item after full alarm.
2. External siren need dip switch 3 has to be in the on position for monitoring else it creates a supervisor fault. When the installation leaflet the external siren is revised, the error in the leaflet needs to be corrected.
3. Handy tip on sensors that fail due to tamper ---- extend the spring to increase the quiescent length.
