Afternoon all,
I didn't want to hijack the other thread on this type of alarm so thought it better to post a new topic...... Apologies if that was the wrong thing to do....
I am looking at installing some home automation/alarm/energy management products which can be interacted with remotely through a phone app, I find the though of sending texts/making calls a bit cumbersome to get a device to do something specific,
It would appear that there isn't much on the market that will cover all of the above bases and I have started to think it's probably safe having an alarm installed with the sole purpose of being an 'alarm'
Researching alarms has resulted in me finding the Yale Smarthome Alarm (not the smartphone one)
I have a few of questions I'm hoping someone could help me out with,
1) Can the Smarthome Alarm panel be installed somewhere remote for example the loft?
Reason I ask is that i am technically minded and i have fitted in the loft a network patch panel, the internet router and a power supply with the intention of later adding the alarm/cctv up there. I see that the Smarthome panel needs to be mains powered and also see accepts a network connection (RJ45). I'm assuming it would be safer for the panel to be installed somewhere concealed where a would be vandal cannot easily access it/tamper with it but with that in mind can a smaller keypad/receiver be installed inside the front door for use in disarming the panel?
2) Does the alarm have the facility to install a repeater in the system to ensure there are no black spots in Yales wireless coverage within the house?
2) The Yale Pet friendly PIR's, if installed are a couple of cats likely to be setting them off on a regular basis?
3) Does this alarm have a smartphone app?
4) The marketing material would suggest there are add ons which can be used to activate lights within house etc when a PIR is activated. Is there anywhere I could did out more information about these add ons? For example I don't want to have to plug a yale plug into a socket and then a lamp into that for it to work, it would be more desirable for the add on to actually integrate/replace a light switch so it turns on room lights.
5) Is this a relatively new system or can I expect a new product out in the near future that would replace this?
6) Have many people opted already for this alarm and with that is there much feedback out there in terms of performance and reliability?
Any info/advice would be great,
