A couple of years ago I was buying a new cordless drill driver and naturally went for a makita as I have other tools of this brand.
Chuck was off centre and wobbling like mad.
I didn't expect that from their top of the range.
I returned it to screwfix, opened another one and it was the same.
Screwfix was very good at letting me test them in store.
I also tested a Dewalt, wobbly chuck although less than Makita.
Milwaukee was centered but I didn't like the feel of it, so eventually I settled for a Bosch professional (blue version).
I later bought 2 extra batteries, a 2amp and a 5amp, so along with the supplied 3amp I can decide on having an "easy on the wrist" battery for light work, a medium or a hard worker all day long 5amp.
All for less than £300.
My 2 pennies.
Thinking of the DCD 796 drill or the DCD 996 drill- not really sure that the 996 is worth the extra money though for what i need?
Then the DCS 931 circular saw or the DCS 570 which is brushless, but not sure for what I need it s worth the money?
The top spec Makita combi drill is the DHP481, although there is a brushed equivalent which is also excellent, the DHP458, which is a lot cheaper (£73 bare from Power Tool world, for example), the main difference being slightly lower torque and shorter run time. Still good enough to pilot drill 6mm steel plate, though. These drills are heavy duty and have high quality metal chucks (without any wobble on either of the 481s I've had). In fact the only Mak I've seen wobble on was the DHP453 "bargain basement special" drill which one of our apprentices bought - I'd suggest avoiding those, together with any of the specials that Screwfix offer, as they allegedly pare down the spec/build quality on DW cordlesses. Whatever else if you want durability that means metal gearbox and metal gears - which both come with a weight and cost penaltyI havent got around to doing an exact match on the Makita stuff yet but the drill I looked at by price seemed to have a lower spec.
Makita changed their battery style a few years back and they are now a miniature version of the 18 volt "square" batteries. AFAIK Bosch and Milwaukee are the only ones offering the slimline "stick" batteries these days - with a limit of 2Ah (possibly 3Ah although Milwaukee appear to have dropped those)dewalt use only the big square battery format where as makita bosch and a few others have both the compact round and some with the larger square battery base
I worked with a guy a few years back who had endless trouble with a M18 combi that had a ticking bearing - he kept taking it back to Rex Crystal to get it sorted, then a few weeks later it would start ticking again! My M12 stuff has been good, though, although I've been on Mak 18 volt stuff since about 2006 (trade)Ive had three Milwaukee M18 circular saws in 5 years and on my third angle grinder, second impact driver.. getting repaired isn't that straightforward if you need the tools now.
we have some makita stuff which have been trouble free.
