- Joined
- 18 Feb 2009
- Messages
- 125
- Reaction score
- 4
- Country
Morning everyone,
Had a bit of trouble recently. I've got an old brick barn (a shippon in Cheshirespeak), which is weatherproof but unheated.
Recently had trouble with with RCD tripping with two specific bits of kit. Both are cat 2, and both will trip the RCD if you touch the switch to either switch it on or off. If it's running, then it runs fine !
I've worked around it by switching on/off at the SO.
Install is TT with a 100mA TD at origin, shippon is fed by a submain to a DB, and then to a CU with all ccts protected by 30mA RCD. It's this one that always goes.
10 ways used in CU, including overhead supplies to two other sheds and outside lights. In the shippon are three light ccts with about 20 fittings (florries & pendants), and two SO ccts with about 20 points. There's a lot of small "rooms" and dark corners in this shippon. It's probably got as many outlets as an average 3bed house, but the load is lower.
Tested the RCD; times OK, tripped at 23mA on a ramp test. A little low perhaps, but not reason alone to change.
This happened a few weeks ago. Came to use the kit again yesterday, and no problems. The only difference is that now we're in a dry spell, and when I had problems, it was a wet spell.
I'm thinking that either the humid conditions led to a relatively high earth leakage in the fixed wiring etc, and somehome touching the switch just tops it off, or (and this is a wild shot) something to do with static. One item was a belt sander (belt rubs against plate all the time), the other is a vacuum that I was using to clean up the sanding dust (dust + motor ?). Could I have discharged a static charge which would confuse an RCD ?
No other kit showed the same problems, and it never trips unexpectedly.
Any thoughts ?
Thanks David
Any thoughts ?
Thanks David
