Hello people I was wondering if you could help me understand how a tncs ze value be 12 ohms. All breakers off main conductor disconnected and two lead test with megger 1553 between line and earth tester set on high as no trip not needed. Reading is 12 ohms,so to check this again I left earth disconnected at board and took reading with earth probe on the neutral/earth block. The weird thing is all zs readings complied with regs, there is no earth on the water so surely the readings cant just be complying due to the gas equiptional bonding? Any thoughts would be appreciated. Thank u in advance
