There shouldn't be any need for a second wiring centre. There is a spare terminal on the 10 way (no 9) which can be used as a second neutral. Don't forget that each terminal number has two terminals.Will I need to use a second 10 connection wiring centre?
With using the s plan plus it'll mean a lot of wires into the same terminals i.e. Live, Neutral and Earths.
The worst case is the Live, which has eight connections: Power In, Boiler live, HW prog live, 3 Valve grey, 2 CH stat lives. If you link two terminals, eg. 1 and 4, that's two wires to each actual terminal.
You could always buy a Drayton LWC3 wiring centre which has 12 terminal pairs. The LWC1 is not suitable.
I would tend to keep all similar terminals together, so assuming a 12 terminal box you would have:
1 & 2 linked: All Lives - Power IN, boiler, HW prog, 3 valve greys, 2 CH prog stats
3 & 4 linked: All Neutrals
5 & 6 linked: All Earth
7: Link Z1 stat to Z1 valve brown
8: Link Z2 Stat to Z2 valve brown
9: Link HW On to HW stat common
10: Link HW stat Call to HW valve brown
11 & 12 linked: Z1, Z2, HW Oranges and Boiler SW live
