To be advised Softus.
I'm in the office so will have to go round and check tonight.
It's a sealed case Potterton Netaheat 10/16. Will I be able to do as described and see the heat exchanger from the top ?
Sorry for the delay in coming back to you - time of year and all that ! Plus I work for a certain kitchen supplier which has gone out of business so not great ! Anyway . . .
Pipe A in the photo goes to 1. Pipe is hot.
A 22mm pipe runs under the floor, can't be seen in the photo, and runs to 2. This is also hot.
A 15mm pipe goes to 3, it's cold. Would this be the water supply ?
4 is a drain cock.
connection 1 on boiler should be the flow, if it is then the pump is the wrong way round. connection 3 on boiler is sometimes a cold feed, by your photo looks to have a cold feed also (point c). if it is the cold feed then it should be between the vent and pump
4 is a drain cock.
4 is a drain cock.
