I thought the same as sparkright, that one of the four holes was probably unused.Do you not think the pull switch looks like a double pole; do they make intermediate pull switches?
Thanks - that's all as I suspected from what you had said.I have no Idea what happened to the cord as it was missing when I moved in. The cord is not visible at all so I am unable now or in the past to use it. When I say working normal I mean what you would expect a switch to do when you use it. Click the switch down the light comes on. Click the switch up the light goes out.
Do these two rooms both have light switches - and, if so, do you know which (or both) is 'related' to the pull switch? If there are two switches, do I take it that each switch just controls the light in one of the rooms?There are no problems between the rooms as far as turning the lights on and off via the wall switches.
Thanks for the answers. As regards the above question, is the pull switch in one of the rooms that has a light switch?Do you know which (or both) is 'related' to the pull switch? - Don't know
Not impossible. The problems is obviously that none of us can do anything other than speculate. As I've said, we do not even know for certain that the pull switch has got anything to do with the lighting! It wouldn't take most of us very long on site with a meter to work out what is going on - but, 'at a distance' .... !!FWIW, my guess is that there are T&E strappers (travelers for PBC) between the two switches, then at the wall switch a feed is piggy-backed off the switch next door and at the rose the switchwire links to the pull cord.
It's probably a 2-way switching system, it may be "in full working order", the unused pull switch may be related to the wall switch in the same room and there may (or may not) be JBs somewhere in the equation - but there is a lot of uncertainty there!So the chances are this 2 way system is in full working order, and we MAY be fussing over nothing.
If that test resulted in the behaviour you/we suspect, it would certainly allow us to understand what is going on at the two switches.Looks like we aren't making much progress. ... Something to try (you can always put it back if I am wrong). ..... If the wall switch seems to operate upside down, then swop over the two reds.
