Bernard, all Intergas have done is revert back to the heavy cast-iron ways of making heat exchangers, however they use heavy copper and aluminium instead of cast-iron. It is good that they have the heat exchanger as the back panel saving space. They run a DHW coil through the heat exchanger which is not very efficient as the specs show. In winter when the boiler is operating the heat exchanger acts as very small thermal store keeping the DHW coil pre-heated. But in summer, as you noted, when the CH is off, there is a long lag DHW delivery at the taps as there heating of the whole heat exchanger. Also the CH coil inside the heat exchanger is being heated. This heat may rise up CH flow pipes heating radiators upstairs. So overall, annually the DHW side is inefficient.My main critique of the Intergas is the thermal mass of the heat exchanger which has to be wasteful of heat when this mass of metal is heated to deliver a few litres of hot DHW and then cools down before the next few litres of hot water are drawn off a few minutes later.
By comparison the thermal mass of a coiled tube heat exchanger is small and much less heat is wasted in heating up the metal of the heat exchanger.
I have aked here and not yet been answered if anyone has a copy (or can quote from) the test procedure used to measure the efficiency of domestic boilers. ( BS 303 -5 ? )
Specifically I am looking for the answer to whether the boiler has to be run up until it is in a steady state condition before any measurements are made.
