- Joined
- 27 Jan 2008
- Messages
- 27,462
- Reaction score
- 3,322
- Location
- Country
Think from memory called a reactor? Basicly an auto transformer, three windings connected to a star point is normal, however one centre tapped winding across any two phases can also be used to generate a neutral following the USA hot wire system.
The problem as I see it is how to work out which has been used? The easy way is likely to have a look, fact I know of two, means there may be more, can see how a simple ohm meter could show between two I know of, but there may be others.
Many years ago we had some portable traffic lights the Peak radar heads were replaced with Mulard and I was scratching my head, as in the workshop worked A1, but in the field the radar would not work, it turned out Mulard were using the centre tap earth and used the 55 volt supply, the generator did not have a centre tap so heads would not work.
We were supplied with a centre tapped winding, which had to be mounted inside the traffic light head or a fault could cause head to become live, while waiting for official units I tried using two lamps in series but found really strange voltages, 70 volt per leg but only 110 volt total, some thing inside the radar head was doing strange things.
I was about 19 then 67 now, so can't remember all that went on, but it did introduce me to phase shift. Since then seen it many times, mainly in small generators, capacitors, inductance, used to control output with some odd results.
I have seen enough weird and wonderful designs not to be supprised any more, but also know not to jump in and assume.
