Exactly. As a consumer in this situation it is at best confusing and at worst misleading.
Might only be Scotland - if at all.Ericmark – you mentioned “some areas of the UK you must have undergone resent training to be able to do an EICR on rented property.” Do you know which areas these are, is there a list somewhere?
I don't know.EFLImpudence said “Incidentally, what inspection or verification of work do they do to an electrician for him to become an 'approved contractor'? Does this include testing to carry out EICRs?”
That is up to the NICEIC as it is only they who made up the designation.So is an EICR "Domestic Electrical Installation Work"?
I agree with you, although -According to the Definitions section of the same document, inspection and testing is included:
"Domestic Electrical Installation Work means the design, construction, inspection, testing and/or maintenance of work falling within the scope of BS 7671 and Approved Document P (Electrical Safety - Dwellings)."
So it seems somewhat harsh for the NICEIC to say in their response to me:
"The NICEIC Domestic Installers Scheme is designed to cover the requirements of the building regulations for electrical installation work in a dwelling and therefore does not cover EICR’s.
Although the contractor may well be competent to carry out this type of work as we have not assessed him for competence under this scheme he is not covered by any NICEIC assurances or warranties."
That's all very well, but you are telling us that they appear to provide (sell!) "(Domestic Installer) Branded" forms that could be used for nothing other than an EICR.(8) Branded forms shall be issued only for Domestic Electrical Installation Work carried out or managed by You.
Not quite the same, inspection/testing your own work would be to your own formulaic design usually, whereas in an eicr you would be checking existing work which may have deteriorated and be to previous regs for for compliance which may be too an unusual design, and using a lot of judgement to decide if it's compliant/safe.-
the reference to inspection and testing likely only applies to the inspection and testing of their own work - even though it is exactly the same as that involved in an EICR and when replacing a consumer unit.
I think that illustrates my view quite well.It's the difference between making a black box and knowing what you put inside it (and testing to see if the results are correct), vs being handed a black box and figuring out what's inside it just by measuring at the terminals*.
* A reference to the old lab practical in physics or electrics where you have a box with 3 terminals and have to figure out what resistors are inside it - being told only if they are connected in star or delta.
I'm getting confused again! ....That's all very well, but you are telling us that they appear to provide (sell!) "(Domestic Installer) Branded" forms that could be used for nothing other than an EICR.
Good point didn't read as far as the board change bit, thanks!Not with a board change you don't.
Depending which John you mean, i think domestic installers just need to be competent to given a requirement, design and install a compliant installation. Whereas an approved contractor must be able to given an installation, decide whether it's compliant, and also classify the safety implications of the non compliance.think what John and Simon are really saying is that some Domestic Installers are not really competent enough to even be Domestic Installers.
That is assuming that 'installer' in NICEIC's category means 'competent to fit from scratch a compliant electrical installation' rather than just able to install cables.
If that is the case then I stand by what I said.
If it is not the case then the system is not fit for purpose.
I'm sure the approved contractor deals with installations that are compliant but are not how they would even design and install a circuit. Whereas the DI would not have that problem to the same degree.
You, of course, as you disagreed with what I wrote - along with Simon.Depending which John you mean,
Perhaps you could explain the difference between the two and why a DI should/would not be able to classify the safety implications - if competent to install it.i think domestic installers just need to be competent to given a requirement, design and install a compliant installation.
I have no idea what that means.I'm sure the approved contractor deals with installations that are compliant but are not how they would even design and install a circuit. Whereas the DI would not have that problem to the same degree.
