Made up a frameless box .... sides are 9mm plywood ..... need to fit hinges ... does not have to be super posh ... never been a fan of piano hinges (but could use one I suppose.
Lid is not just a lay-on piece of ply, but has a 30mm depth edge of 9mm plywood edge as well
Would apply a restictor to limit opeining to 90 degress... so does not have to fold back to 180 degrees.
With only 9mm of wood thickness any suggestion for hinge type ...... if necessary I could add another 9mm strip at the rear just so hinges have something thicker to screw into ... suggestions?
