Hey,
I've got a 2 year old Ideal Isar HE24 boiler.
Recently it started to go off (usually during the night). It would display the fault code FL. normally after pressing the reset button there would be a bang and it would start working again...until today..
It goes through a sequence of trying to start but just as you expect it to fire up the fault code flashes up. I've checked the Condensate trap and associated pipework and its all clear. There is no sign of pressure a gauge on the gas side so i'm unable to check inlet pressure... I've checked voltage at the gas control valve which is reading 0, according to the fault finding guide, if the continuity is ok then the pcb is at fault?
Has anybody experienced a similar problem?
I dont want to pay for a new pcb to find its something else.
Any help/advise or shared experiences is appreciated.
Thanks in advance
Thanks in advance
